Darren Hall
New Member
- uk bedford
Hi all - wonder if you could help me out with a couple of queries - I want to use carbon rods to cut 3mm steel if possible - I have a very small welder and not the funds to be shelling out for expensive gear - I am wondering if a small carbon rod will be ok to use - - my questions are
What will happen (or not) if I run a 6.8 carbon rod at 75amps.
will it generate enough heat to melt/cut my material.
I have no real means of introducing compressed air but! when using cutting welding type rods air is not used in any vids I have seen so could I not cut the area and then knock out the section and clean with a grinder.
If you guys might have any other suggestions I would really appreciate them - allowing for limited funds of course.
Many thanks.
D Hall
Many thanks.
D Hall
