miggymarky
I have adjusted the cut off pressure again on my 3hp Clarke to 100psi and it still blows off for approx 30-40 seconds and then compressor starts again.is the pressure switch faulty or is there another adjustment on it.
Dont know really,all I know how is somewhere under the pressure switch.Where is the air coming from? Is it the safety valve or the unloading valve?
Ok thanks peepsIf it doesn't start to leak air until it cuts off then it looks like the non return valve.
Before it reaches cutoff pressure disconnect the mains and then set the pressure switch to off. If it blows off continuously then the non return valve is leaking. It should give a brief blast of air.
