steveo3002
ive seen silver solder mentioned in a few articles ..suggesting it can be used for repairs on steel ?
can anyone tell me more about it and its uses?
I havn't tried it on pure aluminium yet, but I believe it can be used. I have however used it on Alu alloys ie. Ally/bronze without problems.
It is basically brazing, requiring a flux (unless the rods are self fluxed). Aluminium alloys require another type of flux specifically for that purpose though.
You get different grades of solder. I think generally most use 55% silver content, but I prefer 40% for most applications. The higher the % the lower the melting point of the solder.
Aluminium alloys or aluminiumbronze? Suitable flux aside AFAIK there are no silver solders that have a low enough liquidus point to be usuable on aluminium and it's alloys. Some of the cadmium bearing flavours get close but still talking about 620ish C by which point many Al alloys will have begun melting
As great as silver solder is it often becomes less useful after pricing 1kg of the stuff... [/tongue in cheek]
IIRC it can be used to braze ally to steels albeit not directly... tin the steel side with it and then braze the ally to that using 4047?
It's just a terminology thing, aluminiumbronzes are copper alloys with something like 5 - 14% ally and melting points somewhere around 1000CI was under the impression that different flavours of Ali-bronze can have different melting temperatures. I am interested now to find out exactly what it is that my customer is giving me. Was told it was ali-bronze, given the correct flux and off I went. Have done them ever since no questions - Basically some pipes (ali-bronze?) with brass fittings soldered on. I need to learn to be more inquisitive I think.
