Kafer_meister
Tinkerer
I've got an early SWB Shogun that I'm currently having to weld back to good health. The chassis has has LOADS of work now and is almost done. However, my petrol tank is knackered. It has large holes all over the top where water/mud etc can just sit and eat their way through. I don't really fancy welding it and to be honest it's probably easier to just start again!
So why fabricate one? Well there are no repro ones available, I can't even find a second hand one (which will probably be rusty anyway) and a genuine Mitsubishi one is £400.
I'm not hugely bothered about it looking original, so as long as it's the correct shape to fit in the space in the chassis I'm happy enough.
The standard one looks a bit like this:
They look to be made from 2 pressed steel sections, joined at a flange in the middle of the tank. The flange also acts as the mounting point. How do they make the tank sealed at this point? I'm thinking of a similar construction, a bit like this one with end plates:
http://www.customclassictrucks.com/...how_to_build_a_custom_gas_tank/photo_10.html#
But with a flange around the centre which would be spot welded. I have a proper spot welder. Would it be feasible to seal the tank by then brazing along the inner section of the join and around the end plates? I'd probably only have a MAPP blowtorch. What filler would be best?
I don't really want to mig external corners because it'll look horrible and amateurish. I can't TIG and don't have the facilities. The factory must have used a similar method to produce them in the first place?
I was going to go for 1.2ish mild steel if that's suitable?
