Seventynine
right it's been many moons since i did a bit of aluminium, so i figured i better start from the beginning
problem is i don't remember it being this difficult?!
anyway, the problem i seem to have is the arc is wandering over a fair old area and causing nothing but a mess, as pictured here. i can sort of lay a bead but it's flat, scaly and, well, just a mess haha.
settings are -
6lpm (argon)
1.6mm tungsten (2% CE)
1.5mm 4043 filler
pedal set to 90 amps max
30-40% negative bias
100hz
cleaned the sheet with contact cleaner/stainless wire brush (it was brand new aluminium with plastic both sides)
tbh i tried most settings and didn't seem to get anything much better than the above!!
settings are -
6lpm (argon)
1.5mm 4043 filler
100hz
ANY chlorinated solvent can decompose producing phosgene when heated which is maybe one of the reasons why the stuff is pretty much outlawed in Europe these days and why brake cleaner in the UK is the non-chlorinated variety. Americans need to be vigilant as both flavours of brake cleaner exist over there
