looks fine to meOky doky, cheers.
Does the set up look ok above as I only guessed where everything went?
yeah that is a good way to do it as you don't have such a clumsy gun all mine is on my air fed belt and as you say I can change guns easilyOnly thing I did different was I connected the water trap and gauge direct to my short hose from belt to spraygun and had the pcl connector directly to gun, only reason for this is so I can swap guns but still only need the one gauge and water trap. I also used hi flow connectors
