CO2 is an inert gas, but it reacts with metals when they are in a molten state.Aah! Explains it then. But co2 is an inert gas but when used in mig welding it technically becomes MAG
I was listening to some 'bod' on the radio a while back, and he said that while there was no threat of using all the Helium up.
It was more to do with costs and production, as they wanted it all for filling gizmos![]()
Helium was the origional shielding gas used with TIG (hence it being known as heliarc in some circles) so you've not got much to lose by trying it... if what you've got isn't pure* enough the tungsten will soon tell you, flow rates are gonna need to be higher than with argon and an argon flowmeter will misread due to the difference in gas densitiesWell I got 2 300 bar J's full of He that are surplus to requirements
Five nines pure diving grade
Diving grade???
Divers that go beneath a certain depth (dont know what depth it is though) breath heliox, a mixture of helium and oxygen, usually in saturation diving. Breathing pure helium you would asphyxiate, as helium is a noble gas it would be the same as breathing 99.999% argon surely
As far as i know, below a certain depth and pressure, the nitrogen in air becomes toxic, as dose the usual concentraion of oxygen in the air, so divers breathe a mix of helium and a lower percentage of oxy than is in fresh air which is usualy 21-22%
I suspect that divers mix diving grade helium (or whatever) with air or oxygen before they jump in the waterDiving grade???
More than pure enough for welding then just don't ask me to suggest any amperage settings. I've only used pure helium once before and that was having a play with DCEN welding ally in AmericaFive nines pure diving grade
Yarp diving grade as per boc labelDiving grade???
By 'gizmos' I assume you mean MRI scanners. The ones that need their super-conducting magnets kept at cryogenic temperatures with liquid helium.
Liquid h
Liquid Helium.....????? Thats somewhere in the region of -250degC isnt it???? Blimey that is cold lol
Helium adds heat as it increases the arc voltage. It's also got a higher ionisation potential which is a fancy way of saying the HF start won't work as well and one of the reasons why it's usually mixed with argon- arc starting and stability. Another is because helium is 'kin expensive being a finite resource that's running out. On the off chance anyone is thinking about it balloon helium won't work, it's air with enough helium to make balloons float or something along those lines
Different BOC alushield flavours... http://www.boconline.co.uk/internet.lg.lg.gbr/en/images/Alushield_LUH410_55529.pdf Air Products just do the one flavour (alumaxx?) i think which is 25 or 30% He
