in general drilling disks is a bad idea ( it looks fast ) dut if you drill your bog std vented disk and then give it some serious stick it'll crack, you can radius the holes on the outside edge but not the inner edge, yay cast and a streess riser allways ends well.
ie found that small grooves sometines help but i've allways found the best brakeing performance comes from higher quality matched disks and pads. problem with uprateing brakes i found was as you move up the performance levels in pads there disk trashing propties rapidly increase. thr heat cycels get bigger and faster.
good plain disks, bloody good pads if that dosent work bigger disks
