CompoSimmonite
I would like to use my Marlin Roadster for gentle green laning. It's a trials design so is more than tough enough
Easy to raise suspension for extra ground clearance.
One thought is fiddle brakes to assist if one wheel starts spinning in mud / snow etc. Next thought is could a ABS unit be used, with surplus outputs blanked off, so (rather than the normal pair of additional master cylinders for operate rear brakes when in "fiddle mode") a simple 3 position sprung return switch (left brake operated, neither brake operated, right brake operated) used ?
Basically a manual traction control.
Paul h
Easy to raise suspension for extra ground clearance.One thought is fiddle brakes to assist if one wheel starts spinning in mud / snow etc. Next thought is could a ABS unit be used, with surplus outputs blanked off, so (rather than the normal pair of additional master cylinders for operate rear brakes when in "fiddle mode") a simple 3 position sprung return switch (left brake operated, neither brake operated, right brake operated) used ?
Paul h
