Hi guys
I'm toying with the idea of getting an old transformer based TIG (eg Miller Dialarc). I understand these are pretty big and take a lot of power. The maximum RCD I think I can get for my consumer unit is 40 amps. Does anyone have a view on what power output from the welder I might be able to get before the fuse goes?
I'd mostly be welding aluminium, but likely only a few mm thick. I'm not expecting to be able to weld half inch thick blocks etc.
Any thoughts appreciated.
Cheers
Cheers
they can be as low as 60A
they only charge if u do it twice then they ask what load u have put on them or is there a fault on the wiring all u say is u have had the elecrics tested and its ok , ive got the seals and fuses so just change them . its quicker
