it looks like the weld hasn't sunk into the parent metal, so to speak. Not a great deal of penetration im guessing and maybe lack of fusion in places, but as said above keep at it. Keep playing and try different power settings.When you say "it looks cold" what does that mean? how does a "hot" one look in comparison?
Looks like it is sitting on top of the plate knock up the power a bit and you will see the bead sink deeper into to the plate. It will look a bit flatter as it will have penetrated more into the base metal. This will be a much stronger weld.When you say "it looks cold" what does that mean? how does a "hot" one look in comparison?
Don't forget that cleanliness of the metal at the point you are welding is just as important - if not more so - than technique. Any rust, oil or paint will prevent full fusion and introduce contaminants to the weld puddle so that it will be weakened.
Not the best weld pictures, but the only ones on me phone.
Your looking for a smooth, consistent width and throat thickness along the length of the weld, the edges of the weld need to fuse into the parent metal.
View attachment 41700 View attachment 41701
New lorch Paul?
Not always. It is good practice to remove mill scale, grease and dirt before MAG/MIG welding, but in industry, in practice, it rarely happens. Burning through the millscale does 'soak up' some power, but with our 400-500 amp sets it can easily be compensated for. When using a set that is on it's limit for the material thickness being welded, it is essential that the steel is cleaned back to bright.
