gerrymoore
CNC expert (well, getting there!)
- Wirral UK
Sounds daft but I have a full tin of gloss but need a matt finish....rather than go and buy another tin, is there a way of making the gloss matt?? Yes I know I'm stingy
If you are using a spray system you can spray a final dusting coat from a distance to give a matt finish,
If you are brushing, they you can rub the varnish down afterwards, 240 grit for a matt finish through to 1000 grit for a satin finish
only problem here is it ends up a rough surface as its full of overspray
