restorer
Klaatu Barada Nikto
Hi all,
Can anyone recommend a dial vernier caliper as I'm not familiar with makes or brands? It'll be mostly used for wood work/turning, so super-duper accuracy is not critically important. I need one with inside and outside jaws. And with a depth gauge rod if possible. I'm not so keen on battery digital ones, but will consider any you think I might want to take a look at. (I steer from battery tools because they need batteries
My budget is £50 but will nudge up if it's just a matter of a few quids. 12" (300 mm) ideally. Doesn't need to be top of the range quality. Good enough will do.
Thanks in advance.
)My budget is £50 but will nudge up if it's just a matter of a few quids. 12" (300 mm) ideally. Doesn't need to be top of the range quality. Good enough will do.
Thanks in advance.
Unless you're into an area which requires seriously precise work, you don't really need owt else, and if you need to make two parts fit precisely, I prefer to use the parts themselves as the final measure devices.
