secretsmoker
Has anyone out there ever attempted to build a press before?
My friend is a penniless artist (although recognised by the Saatchi people) and I stupidly suggested that I might be able to build a decent sized press out of scrap.
I have no doubt that this is possible, however it will be the largest project I have built to date.
First thoughts were to try to do something similar to a tried and tested design...something like...
Just in case the image disappears it basically consists of a table frame which supports a plate. The plate is driven by a handle to slide from one end of the table frame to the other. On top of this sitting in the centre of the frame is a roller with a mechanism to adjust the downward pressure against the plate being driven underneath it.
The whole thing will ideally fold up, although I need to learn to walk before i try to run! I may well have bitten off more than I can chew with this project, although that is what I first thought with the rust repairs to my car, and that turned out OK!
First things I need to find are some gears/rack/pinion/worm gear of some description for the sliding plate. Any suggestions on commonly scrapped items containing gearing? (looks over at £20 MX5 open diff and spare gearbox...may be overkill)
I also need some suggestions for things I could use as a roller.
Not sure how big this will be yet, ideally to print at least A3 size.
I have a long way to go before I start chopping and welding but any input is very weldcome!
