johnakay
you would of though that I should know this by now after nearly 40 years off welding etc.
also I'm not the best of welders but I've always got by.
for some reason these day my mind seem to draw a blank as to why and what nots etc.
I can't seem to get a decent welds on thin walled tubing.
I seem to get a rather heavy weld build up even though I have the setting right and speed movement.
I've even had the setting lower but it appears the weld looked cold and not enough penetration.
wall thickness 1.5mm x 19mm,16mm and 12mm tubings.
I'm currently using .8mm wire with argon mix.
I want to put a thin bead of weld on the tube.
most of my welding is on 1.5mm to 3mm max with the odd 4mm or 5mm but rare.
I'm thinking now that perhaps I'd be better off using .6mm wire rather than .8mm.
I wouldn't mind if I can get welds like these in the picture below(not mine), Iknow its much thicker tubing I know.
