TonyWilk
2-Pint Welder
I've got a MAO's Electric, branded 'Highweld', TIG/Plasma cutter.
Zero info on the plasma cutter in the "manual", but after reading a few posts here (and reducing one tip to slag
) I've happily diced up some 3mm stainless and it seems to work just fine.
Then, after reading several other posts on here, I got a bit confused... should the tip be in constant contact with the piece you are cutting ?
Since my torch has one connection to (-)/air, a 2-pin connection for the switch and the return (+) clipped on the piece, I guess it has to be in contact to work.
In practice that seems the case... have I got it right or am I missing something ?
Yours,
Tony Wilk
I believe the torch is an "SG-51" type with bits that look like this:
) I've happily diced up some 3mm stainless and it seems to work just fine.Then, after reading several other posts on here, I got a bit confused... should the tip be in constant contact with the piece you are cutting ?
Yours,
Tony Wilk
