madkayaker
Pro sparkey Pro Welder
The unloaded will just lift when there is sufficient pressure behind it
			Ah ok I'm starting to understand, so that arm under the fuel tank moves does it whilst running?the engine will self regulate with a governor when power is needed under load or its idling and reduces the fuel thats what the linkages do operated by an air flap and the motor fan on the flywheel
What I'm trying to explain regarding the spring happens if you watch this video at 3.35, if he stops moving the camera for long enough for you to see!
Thanks for help gents
well explainedthat spring is connected to a flap behind the red cover and relies on air created by the flywheel to regulate the speed, if the engine slows the air produced is less which allows the throttle to open which obviously speeds up the engine increasing the air again regulating the throttle
 mine was near enough
Thanks for the advise, I have always had compressors with electric shut offs, so this thing is just alien! I'm glad you think the capacity is enough, I think your right in saying that it's the pressure that's the most important here.Right--- the pressure steadly builds in the tank untill a preset pressure is reached, the unloader valve then opens and the tank pressure flows into the unloader pipe to the cyl heads inlet valves there is a small piston in each that then holds the inlet valves open, stopping the compressor producing pressure but no significant air flows through the unloader pipe , it remains like that until the tank pressure drops enough for the unloader valve to pop closed it doesnt do it slowly it snaps closed that then allows the inlet valves to shut and the compressor starts pumping again and creating pressure that then builds up the tank and the cycle begins again.
But that engine will produce enough power near to idle to keep the pump 'ticking over' it will produce air but not as much as when running at governor speed.
But you dont need masses of air all the time so just have a throttle cable and you decide how fast it runs.
It only runs fast to give the compressor its specified max CFM but will still produce air at a slower speed, the power required from the engine is relative, the slower the compressor revs the less power required from the engine, down to a certain point at which the engine will stall so you just need to keep it at its 'happy speed' untill you decide you need more air, then YOU open the throttle.
I used to run my tyre machine off a 1ph compressor half the size of yours, when fitting tyres in the middle of the night, with no problems, it saved starting the big 3ph thumper that would have annoyed the neighbors because it ran for ten minutes to build up, whereas the little 1ph was up to pressure in a minute and most of the time with tyre fitting it is pressure not flow that is required ( apart from a difficult bead ) then leaving the tyre valve out was tried first then, I used a one shot bead blaster, again that was pressure in a small cyl , so the little compressor filled that fine.
I think you will only need the compressor to run fast for the first fill from empty so save fuel and noise!!
I have got one of those engine s somewhere A bit late now to look but how most work is they have a cooling fan on the crank and a flap in the cooling air flow to the cyl head as the engine speeds up the flap is pushed by the airflow against the spring that then closes the throttle because otherwise the engine would 'run away' as the engine revs drop the air flow is slower that allows the flaps spring to pull the throttle open until the revs keep the fans airflow at a predetermined point ie the 'set by you' governed speed.
The flap BTW is NOT the butterfly in the carb it is a tin flap that is blown by the cooling air flow.
So you now have the situation that the pump begins to work, so it slows the engine slightly that lowers the revs and therefore the fans air flow which then allows the flap to be pulled back by its spring that then opens the throttle and produces more power and increases the speed ie revs up back to the preset fans airflow. Keeping the engine rev at a steadyish speed. That works until the engine is at wide open throttle for the given speed but you have that much load the revs begin to drop, then you are beyond the rated power of the engine and it will begin to stall. YOUR engine should NEVER reach that situation because it is more than powerful enough for that pump.
Also, would 1/2" pipe be too restrictive for an exhaust?, it would be around 1.5 meters long, not sure whether to cut small hole in roof and poke it out of there, or just aim it towards back door (but would mean doors would always have to be open)
It sounds to me as if it is over fueling Ie the mixture is wrong or the float valve is leaking allowing too much fuel into the carb and it is flooding the engine the usual signs are the engine sounding 'heavy' smelling of fuel then hard to start when warm give it full throttle which gives it more air and helps clean the plug, and then it starts, the way to test is to close the fuel tap as it is running if it picks up and runs better for ashort time then begines to die as it runs out of fuel, you then open the tap and it picks back up then starts to hunt again repeat closing the tap etc, you are then controling the fuel into the carb, which indicates the carb needs stripping and cleaning.
Oh and managed to lose the air filters, literally have only had it running for 2 minutes though until I find them!
I agree that can give you an idea but only if it had run for any length of time,unfortunately it has only been fired up for short bursts probably on choke so the plug will tend to be black anyway even if the engine/carb was ok, and is not a definitive test. So by running it on the 'fuel tap' for a length of time can actual get them to run cleanly for a time which then can get rid of any waxy fuel from the carb or the vibration can free off sticky float valves etc.take the plug out if its black and sutty then the above applies
Thanks for such a detailed response, Its clicked with me now, i had a tinker with it earlier, runs great, but occasionally stalls, and struggles to restart? Then once started (normally have to put it at high revs to start) it will be fine again for a few minutes. I have drilled a small hole in the fuel cap just in case a vacuum had been created, but no difference. I'm not too sure how much it would affect it, but the throttle arm has a lot of resistance, where it is bolted down, this keeps the arm in whatever position you pull it too, would this affect the governor spring? I have loosened it off, but haven't tried it since to be honest.
