Been having some issues with my TIG welding, hoping you guys can give me some pointers ?
1, I'm struggling to find the right amps to use on fillet welds. If I lower the amps, I struggle to get the puddle started down in the root (although a dab of rod into the arc seems to help start it), if I raise the amps I end up with the puddle formign too quicking and undercutting on the vertical side. If I angle the arc to the horizontal piece, I loose the puddle in the corner of the joint and the bead washes out onto the flat. Welding on 3mm mild between 80-90 amps, starting high and reducing as the piece heats.
2, Been welding 20mm OD tube to flat plate. The radius around the tube is too tight for me to do in one continuous weld so I'm doing it in maybe 4 small beads. The problem I'm having is at the end of each bead, no matter if I slope down / post flow for longer etc or pull the arc back along the bead, I'm getting a small raised peak. Why is this and how can I avoid it ?
3, Gas coverage, I'm using a No6 cup for most welds (mostly 3mm fillets) which allows me to get down into the root with the tungsten but not stick the tungsten out too far. I'd like to use a bigger cup as I think I'm running a little hot (welds are mostly grey) and the tungsten point (1.2mm thoriated) is dulling very quickly, requiring re-sharpening maybe after 3-5 welds (but not due to dipping just dulled). How far out can I run the tungsten with a No10 cup for instance ?
Thanks
Phil
Thanks
Phil
