Splatterer
Hi all, here is the centre stand off one of my FJ1200s. This one is the reference bike as it's got tax & MOT, but it needs a light coating of care to bring it up to spec. The other two are in need of much more fettling. So I'm fitting a centre stand off one of the basket cases.
Now the stand is pretty wobbly to say the least. So I'd like to know if it's possible to add some metal to the bolts and the stand holes to bring it back to a less wobbly spec.
This is the construction of the stand. will it bulge out when it heats up and crack when it cools?
he stand with oval holes, which would be better round.
This is the total of hole I'd like to fill in.
This is a bit of the stand which has worn against the spring, but needs a bit of metal adding in to take up a couple of mm.
These are the bolts, which have a number 6 on the end, so I'm assuming them to be HT. Is it possible to add some weld and then grind back.
