Hi all,
I just received my new beaut MIG welder (165A, 8 power settings, GAS/GASLESS operation etc). Looks great and I've been told it's got the same wire feed mechanism as the Clarke units.
Anyway, I'm having trouble deciphering how the wire feed components fit together. Maybe if I had a 5kg wire spool I'd be able to figure it out quicker, but I don't, thus my post to you guru's
The MIG came with what seems like two springs, a small spacer (pictured between the two springs) and two large "collars" of some sort. I'm not sure how it's all meant to go together. I assume the large collar(s) are to be used for larger 5kg spools? What about when using smaller 700g - 1kg spools?
The bit on top of the shaft locks down onto the shaft to hold the wire spool assembly in place.
Here's a pic of what I'm talking about... any tips/suggestions?
