hunter27
Pete
- Lancashire UK
Hi
I have recently bought a small R-tech 30A plasma cutter but have not really used it properly yet but now I need too cut some 8mm thick 304 stainless steel plate.
The 8" square piece I bought cost me £30 inc delivery and I have non to practice with or waste.
I need to cut it into 4 pieces and then cut a 35mm hole in the centre of each piece for a pipe to be welded in.
I am worried that if I try to use a hole saw the stainless will work harden causing me more problems.
I am planning to set the cutter on full and follow a straight edge for the straight cuts and then clamp a template over the stainless plate and cut around the inside of that for the holes.
this is from R-tech web site in the spec.
Thanks
Pete
Thanks
Pete
- 8mm Genuine clean cut on mild steel, 6mm Genuine clean cut on alloy and stainless steel
- 12mm severance cut on steel
