visor_down
- UK
Know there are a lot of knowledgeable people on here so thought I would ask if anyone has any pointers on the below.
Car I have bought suffers from a deep bassy vibration that resonates through out the cabin when going over uneven roads.
You can feel it but it is not more noticeable through pedals or steering wheel, it is the whole cabin. It seems to originate from N/S/F however given its low frequency it is difficult to tell.
It happens as the car goes over undulations in the road, not the like of potholes etc, but dips that make the whole car oscillate, it is at its worst as the car reaches the bottom of the suspension travel (for example as you come down the other side of a hump back bridge, however does it on the slightest uneven road). It seems to happen at all speeds above around 20mph, however if it is a flat road and the suspension is not loading/unloading it doesn't do it.
If you dip the clutch it doesn't do it at all, even over undulations
Any ideas on this one?
Cheers
Cheers
Want to find out what the vibration is first, if it is anything too expensive it won't viable given other issues with the car, would a CV joint / driveshaft issue only manifest itself with the clutch engaged even though they are still spinning with it dipped?
