- UK
I have a slightly worn shaft that measures 18.9 OD on average, it is slightly out of round and a little worn where a previous bearing has spun.
The hole into which the thrust bearing goes look ok and measures at 41.2mm.
The nearest bearing i can get is 41.6 OD which should be a tap-in fit, but is 19.1 on the ID.
I know the ID isnt too far off but i'm bothered about it spinning again. Its a hand-windy handle so no speed on it (Levelling box handle), but the way it is at the moment the centre shaft spins inside the bearing and doesnt even touch it. The bearing is fairly chewed up inside but luckily the bearing seems to have taken the majority of the damage rather than the shaft. The shaft measures differently on its diameter depending where you measure so difficult to get an accurate dim.
I can't weld the shaft, and no real machining facilities. Is there a quick fix way of ensuring the shaft doesnt spin. I can put retaining compound in there but don't put much faith in 'non-mechanical' methods.
It's a pain to get back into once the thing is back together and if it spun, i wouldnt know until it jammed up.
What about forming some 'pips' with a chisel or similar on the shaft to get it to bite? Bodging territory? Hmm.
