ericoneill
New Member
how do i get a good stack of dimes look on my tig welder ,it doesnt have pluse as an option ?
Practice. Its not down to what welder you have you just need lots of practice. When welding you need to pause and add filler then move, pause add filler. Each time you need to ensure you move the same and add the same amount of filler. Obviously the fit up needs to be spot on to make life easier
You can always use a metal heatsink underneath - nice large block of metal to dissipate the heat - or weld a bit, let it cool, weld a bit, let it cool...etc
I would be more around the 50 amp range your better of getting some ss sheet the same thickness to practice on untill you can get the same look, then move onto pipe. Whrn praticeing mess around with the amps, touch angles, travel angles untill you find what you comfortable with70 amps mybe there sch 10 ss bends
very hard to get that dime look ive seen some vids it seems easyer to achevie with plusing lolPractice. Its not down to what welder you have you just need lots of practice. When welding you need to pause and add filler then move, pause add filler. Each time you need to ensure you move the same and add the same amount of filler. Obviously the fit up needs to be spot on to make life easier
The stack of dimes you refer to can easily be achieved without pulse,
The "stack" is formed by various factors, some being moving the torch in regular intervals at the same speed and the correct heat, too much heat and you'll lose that sharp weld definition you're looking for,
LOTS of practice on joints with good fit up with varying methods and you'll eventually get the quality and appearance you're after.
If you havn't already got them get some 1mm filler rods,
when using the 1.6mm or thicker rods some people tend to without realising weld hotter than needed to melt the thicker rod which then overheats the pool and looses the definition.
X 2, I never use 1.6 rods on exhaust tube, always use 1mm
As for amps defiantly not 70, I use a pedal but would stab a guess at 40-45 amps.
As Gary said tight fit up is one of the keys to success
good info thereHeck-sorry about second post I forgot some things:
I've been practising on old motorcyle exhaust, I cut into the pipe with a hacksaw but did not cut right thru, this was so I could do multiple runs on the same bit of pipe without repeatedly setting up.
The width of the hacksaw kerf is really too much- dead easy to blow holes-I mention that to illustrate the need to butt the joints up if poss.
When I did blow holes I switched to 1.6 mm filler (1.6 tungsten in torch) to fill in.
My plan not tried and tested for cleaning inside tube is to try a flexi shaft on my drill, with a round wire brush as used by shotgun shooters.
Plan B (if I decide that exhaust fabrication is worth the hassle) is to use steel tube and if my welds do not improve, I'll use exhaust wrap to cover them.
Plan C is to cut and tack up the tubes and get the welding done by a pro.
I need to find out if non stainless tube needs back purging as well.
BTW , I understand the need to back purge stainless is :
A- to get a better finish on the inside of the pipe (less interruption to the flow of the exhaust gases)
B. If stainless is not back purged it is likely to crack.
C improves the puddle.
ABC points were taken from this chaps video:
https://www.youtube.com/watch?v=02U0H15_WEg&list=TLyKBAZ_3BbP9888MOTzKm6AdJxm5duNOm
Hope that helps.
