- England
A couple of the lads have been on a site job, they bought back a piece of it, a 5' diameter fan, from the rear of an incinerator. It had to be removed, but it wasnt shifting.... so they gassed the shaft
Been soaking in wd for a few days... tried beating it out with a drift and sledge...broken handle... none of it
Press brake, barely enough daylight to get it in there any sense..
Heat the boss, and beat it...
Welded rsj across the fan body, and portapack it....
Weld a bit of solid across the end of the shaft, then a wedge from each side
Find someone with a substantial H frame press, no joy
Okay, only option left that i could see... strip the pressbrake, get it in there with some 10mm packers underneath, press it 10mm out, then cut it off, press it, cut it...
The initial breaking of it the gauge went up to about 150tons
Still, every 10mm or so is still taking 80+ tons.
Me sledge hammer didnt really have a chance
Any tricks to getting stuck fast keywayed shafts out?
I think working in constant heat had frozen it well in there
