ferguson1947
New Member
hi all just been given a sip airstream compressor model number as3hp/100 with no plug will this work off a 13 amp plug or need a 16 amp supply
a residual current device rcd works on earth leakage current not load current3hp is 2.2kw and is technically within a 13amp circuit at 9amp you may find depending on the starter type that it blows the fuses all the time. I tend to run everything in that range on 16amp or 32amp plugs. You can pull a 16amp socket of your existing socket ring main without a problem and then the RCD will take the load rather than a standard 13amp fuse.
My 3kw workshop heater runs on 13amp fine. But the start load is tiny.
a residual current device rcd works on earth leakage current not load current![]()
