if u can file it it is soft. if it just runs over the top and doesnt cut its hard .oxy acet and braze would be the quickest and easyest and a quck rub up
It marks it ok, the bolt itself is untouched.
my mate has an 8 shot pump on S1. its scary how fast you can release 8 shots with it
. I`ve welded up the action bar as both medway (An american co.) & chambers gunmakers (uk co.) are out of stock. Chambers do have the forend support wich I`ll order, just got to wait before I can test it to see if it`ll hold up.there are numerous massive gun parts warehouses in the USA that have every part known to man, it's probably a cheap part.
https://www.gunpartscorp.com/Manufacturers/SavageStevensSpringfieldFox-33479.htm
the bolt then is hard, and the part you need to repair is soft if ive read the previous post right.
is it magnetic?
Yes, they can be had on a section 2 (shotgun) certificate with a magazine capacity of 2 + one up the spout, just the same as semi-autos. If the magazine capacity is over 2 they go on section 1 (Firearm) as a high capacity shotgun.
This one is a section 2 though I do still have an unfilled slot for a section 1.
