After much delay I need to get on with providing a 16A supply for my SIP 13/200 belt drive compressor (see http://www.mig-welding.co.uk/forum/showthread.php?t=40074).
The garage is very close to the house and has been supplied with power from the main consumer unit (about 5 metres away). One cable supplies the lighting circuit & a separate cable feeds the 13A sockets (3 sets of double sockets). This circuit also supplies the downstairs sockets including the kitchen (not cooker). This has never given me a problem despite running a freezer in the gargage (permanently on), a lathe, mig welder, a direct drive 3HP compressor as well as the usual power tools and music. The circuit is protected by a B16 mcb and the 6-way consumer unit (installed prior to 1999) has a 63A 30Ma RCCB.
Ideally the C/U should be relaced with a larger 17th edn unit so that I could provide a dedicated feed to the garage but money is tight atm. My questions are :-
- will it be OK to fit a 2-way consumer unit in the garage with 16A mcb's supplying the 13A sockets and the 16A socket(s) on separate circuits (using the existing feed to the garage.
- does the C/U in the garage actually need a master switch or can I fit one simply with the 2 mcb's?
Any and all comments much appreciated
