BChild
SIP - enough with the mods!!!!
OK so for many years the important function of my garage has been storage - as I have finished of projects the need for storage has been reduced
I had some one on one welding tution with Malcolm a while back and one thing I took away with me was a desire to build my own welding bench
So my garage (archive picture)
Now I needed a work bench and my own work provided the basics FOC amazing what companies throw away
Obviously I hadn't really much need for another racking unit but I reckoned split into two I'd end up with a 12 ft long work bench
I planned to have a woodworking bench with vice etc mounted and then the second half as a welding area
So I purchased a 3 ft by 6 ft sheet of 5mm thick steel
Bench is 6 ft by 2 ft
I wanted a slight overlap to allow clamping of items to the work surface
I also wanted to put a front lip and back lip to stop the surface moving as well as stop stuff disappearing of the back of the surface
I think I got it fairly straight and level
Backstop
I know the back is not quite vertical but I need to run some cables behind the welding bench
Other pictures
Backstop
Other pictures
LC ?
