Hi. I recently made the jump from an old clarke machine to what was called a professional mig. I've used loads of peoples mig set ups over the years and always had good results.
This is my new machine
I am using new wire and argon/co2 mix at 13 lpm
The tip is clean and gas passages clear enough to blow away grinding dust
But the problem is my welds are porous and I don't know what's going on?
From the lowest setting I get this
Mid setting I get this
To the highest setting ( amps) all plugged into a 16A supply I get this
( I'm embarrassed to show this) I upped the gas lpm for this too..
All using 0.8 copper coated quality wire and clean steel
Has anyone any ideas what the hell I'm doing wrong?
How sad am I noticing a Manta front panel upside down on your bench?
Should have checked that when I took it out of the box 3 years earlier!
