julianthegypsy
- Cirencester
I just won one of these on evilbay, cracking piece of kit as it has a backgear so speed goes all the way down to 80 rpm and all the way up to 4000! It's the low speeds I wanted for drilling big holes, which I do a lot, and it takes a morse taper, perfect for my bigger drills.
I have two problems however. It says to use Tellus 23 oil, which I believe is now tellus 22, and it says to drain it and refill with 1/3 to 2/3 pint every three months. Fine. Except I can't see a drain plug anywhere! It says that it has one, but I see no sign of it. It also says not to top it up unless I know how much is already in there, which of course I don't! Does anyone here have any advice, and also does anyone know anywhere close to Rugby that would have tellus 22, assuming that is the right equivalent! Many thanks, Julian.
. I did initially come to the conclusion that I need an estop in kicking range fitted asap - that was months ago now and has largely been forgotten - just got to use common sense and forgot about holding things with your hands not that anyone does that of course
Did yours have the fancy cam operated hold down? not sure if it was standard but damn it's useful - so much so I've kept putting off getting a decent drill vice for it as between that and a record number 3 there's not a lot I've struggled to hold down.
