Hiya,
just about to join the club and pick up a mill to refurb/commission. Don't think I'll reach Andy's level with his Tom but you never know
Anyway's need to get a 3ph supply rigged and probably going to go down the Digital converter route.
You can buy plug n play systems from Drives Direct, or the converter itself like this one http://www.invertersdirect.co.uk/Product/DSA7/7%C2%BD-HP-220V-to-415V-3-PHASE-DIGITAL-PLUG-PLAY-CONVERTER-INVERTER
The converter on its own is way ceaper so wondered if anyone had any experience of programming these for the specific machine?
I will have multiple motors for the spindle plus cross feeds and suds etc and the spindle motor at least is 415v and not delta 240 compatible as far as I can see so the plan is to use the converter to give me a 415v supply I can plumb into the mills main board and run the motors of the original switches/wiring.
Any thoughts?
Cheers,
MM
Any thoughts?
Cheers,
MM
hence looking at 2nd hand units or rotary's
