cardiffrob
- Wales, Llantwit Major.
I'm playing around with making radiator cowls for toy vintage cars. Making them in alloy is a PITA with cracks due to the thin material getting thinner with filing down. So, if I were to make them in steel and use anything other than standard mild steel TIG rod would it cause a problem with the chrome plating later? The 4043 rod is a different colour to the ali cowls I used previously so the joint shows up and I wanted to avoid that problem altogether with the steel versions.
Any suggestions would be most welcomed.
Thanks
Thanks
