Is there anyone near me around the Warrington Cheshire area that's good with the TIG or MIG and would like a little work?
I've got a steel engine sump (1 mm steel) that needs welding. The sump is a special aftermarket deep sump that is too deep for the application I have and so I've cut an inch out of it (removing the factory weld in the process) and now it just needs re-welding back up. I've taken time to get the cut edges flat with a surface plate so the edges butt together very accurately. Here's a couple of piccies so you can see what the job entails. I need a nice weld without any pinholes etc. Anyone interested?
Cheers Julian
Cheers Julian
all you need is 0.6mm wire, tack it every inch and then weld in between every 3rd or 4th just to keep the heat down. I'd also weld the inside aswell after finishing the outside just to make sure it doesn't leak.
