.........Only problem with the mercury is it hasn't got the oomph to start up on the higher two of the five speeds. ........
shell out and put a single phase motor on it .not much point in having a good drill with a dodgy motorYep, definitely the DIY motor conversion which doesn't give the motor much starting torque. In the higher speeds pulling on the belt gets it going!
yes with reduced powerWhy? It's been like that for a year or more, runs a treat with plenty of torque at the speeds I need and is a simple conversion back to three phase if needed. It doesn't have a dodgy motor. The purpose of my post was to let the OP know that three phase drills aren't un-useable on single phase.
no use when u want to run the drill to its full potentialgood for uNo lack of power, just starting torque same as if the capacitors gone on a single phase motor. BUT ONLY ON THE TWO HIGHER SPEEDS WHICH I HAVE NO NEED FOR. I WAS IN THE SAME POSITION AS THE OP AND THIS WAS THE SOLUTION WHICH I AM VERY HAPPY WITH!!!
