wheresmejumper
Banned
2-3 feet maybe?
whatever,it will be unbearable to have that machine catch up
so priced it so i wouldn't get the job or so i thought ......ive got a 180 amp oxford type oil cooled welder you can borrow and see if its up to the job.if the Radcliffe you refer to,is the one near bury.
Ok i have seen some 250amp single phase with half denet duty cycles
nowhere near big enough
40% at 200amps,you want double that,at least
preferably 100% at 200amps.
second hand is all you will find in your budget.if its new,its too good to be true at that price
125KVA!? Are you planning on running half a dozen 350 amp sets at the same time then?
Put it this way, any halfway decent 150 amp inverter stick set will pump out enough juice to run a 3.25mm rod all day long, what's more, the marvellous little machine will do it off of a 13 amp plug. So it won't cost you £40 worth of diesel each day.
A 3.25 is all you need for 6mm steel and it's surprising how fast you can go once you get proficient.
