I know I am asking a question that will of been asked several times. I want to run tools such as needle files, grinders, cut off tools etc and I am wondering what combination of tank size and cfm would be required?
Cheers People.
I have just wired a 16a commando socket for my 3hp compressor - could easily have went for 4hp but its enough for me. Clarke SE16C150
After fitting the commando socket though, I started thinking, why didn't I fit a 32A? So I ended up fitting one of them too. So now I have bought a 200A welding machine because there is nothing stopping me.
What I'm say is, are you better fitting a 32A supply and if you need to use something with a 16A plug you can use a means of lowering the circuit breaker capacity. This would provide you with enough to cover all bases and any future machines/large welders
I bought a se16c100 compressor from machine mart, 3hp 14cfm displacement. It runs a da sander but does have to work hard although sander never slows down, blasting is ok and it runs a spraygun fine so I would say this would be a minimum if you want to run tools. A bigger receiver would give more reserve but once it's empty you are totally reliant on the compressor output to maintain running the tools. If I needed more air I would just add another compressor.
32A would probably be a good idea as we are having power newly installed in the garage and at least a new consumer unit. I think a 14 CFM compressor will be suffice as i have a couple of smaller ones to back it up if needs be. Thanks for all the advice.
Keep your eyes peeled at your local machine mart as they sometimes have some bargains in the returned items, last time I went they had a dual 3hp compressor with 270 litre receiver for less than £700 which is a massive saving, they also had a 3hp 150 litre one at a good price. Failing that buy something cheap off them and wait for a vat free voucher to arrive, I bought mine with a voucher and saved nearly £80
