mart
- South Yorks
I am going to buy some reconstituted foam rollers for my weight bench (because I am lead to believe that this is the firmest type of foam know to man (or woman). How am I going to bore a hole through the center fairy accurately but it does not have to be perfect. (I have already considered a hot poker)
I’m going to upgrade the foam cushion rollers on my weight bench because they are such poor quality I can feel the steel bar (that runs through the center) pressing in to my leg(s)
Now I can hear you saying, “Mart, just buy some proper ones online yer tight wad”!
Trying to source some professional grade rollers (like they use in commercial gyms) is like pulling teeth when I get on the phone, but it was a woman on the other end of the line.
“What make is your bench” ?
“That doesn’t matter because you only need the internal diameter of the roller and maybe the length / width of the roller”
“But we need the make of the equipment”
But I want to buy rollers that are designed for a commercial grade bench not my bench, and I can give you all the sizes that you want”
“But they are all different, we need to make sure it will fit your bench”
I’d lost patients at this point. What if I have put a different bar through the frame. It is not going help anyone identify the roller size type now is it? In fact the one in the pc is not the orginal bar.
The pic is of the rollers that I am using at the moment, that I want to replace.
