Laurence B
Planning on painting my block and gearbox gloss black. As there's quite a few choices out there could someone suggest a good quality/ heavy duty one.
Cheers
Cheers
i used smoothrite enamel on mycar block and on the cylinders on my bike engine it stands up wellFound a thread but it only covers painting blocks with 2k and I don't have the equipment to paint with 2k that's why I was asking about other paints, I was planning on using an enamel. Just wanted to see if there was a brand that is a lot better than the others.
if its an ally block u would be best paint it with acid etch primer 1st then enamel topcoat otherwise it will just flake off sooner or laterDid the halfords paint hold up alright? Don't really want to be messing about priming and lacquering it I thought the brush / aerosol enamel paint was good enough to go onto a cleaned & prepped alloy block just not sure what brand to use
You either need Epoxy primer or Etch for bare aluminium.
EDIT brightspark types faster![]()
Will the acid etch be alright with the heat? Ordered some Por-15 engine enamel after reading quite a good reviews on another forum.
