keithski122
Now my beetles nearly ready for paint I have a couple of questions.
I'm going to paint the outside in a booth which could be heated (oven) if I need, though I'm hoping not to.I won't be painting until the beginning of sept.
Should I use normal or fast activator with the clearcoat? I've been using fast at home to do the inside, but my thinking was if I use normal then it should flow better and give me less chance of dry spots, though if I use fast less chance of runs.
How much base should I mix up for one coat? I'm expecting to do 4 or 5 coats but don't want to run out partway through a coat, I've got 5ltrs of base so plenty to do the job.
How much clear per coat? Expecting to do 3 or 4 coats so ordering a 5ltr max meyer kit(7.5 ltrs mixed).
Cheers.
Cheers.
the hardener won't make much difference, if your getting runs your putting it on too heavy
