Tin Can
I have 2 x 30watt front foglamps on my car and want to have them on in daylight hours as day light running lights for increased safety. I will wire them from a fused feed via a change over relay so that when the side lights come on they automatically switch off and then revert to there normal use of fog lights used as and when. My problem (i think) is that when they are on as DRL's there is a back feed potential so i was thinking of wiring in a couple of blocking diodes, so my first question is how do i calculate the value of the diodes needed and secondly are they voltage specific ie only work on a positive feed . Thanks in advance and can anyone recommend a supplier (i have seen blocking diodes for small solar panels etc but i have no idea if they would cover my 2 x 30watt lamps) - Mark
