mike 109444
What is 2k paint normally like to strip from a panel.
Reason I ask is it am having lots of problems removing the paint from various parts of the car I am doing. The car is a 61 Consol Capri. Ori colour is grey and it must have had a respray in the past and I believe that it was done by sanding the original paint to form a key (but not remove) then primed and painted. The problem I have is that in the areas where this respraying has been done is as tough as old boots. If I use a sanding disk with say 36 grit it clogs to the point of not removing any paint in a few passes. The primer under it is also the same. Even tried an angle grinder to knock it off but that clogs as well. Ended up using a knotted wire brush on angle grinder and that struggled to shift.
The paint is quite old so it’s not a case of it still being soft from a recent paint.
Is this typical of 2k?, hope not cos there are quite a few places it look to have been used.
