Hello everyone, I'm just after some advice on repairing the sill's on my MK2 MR2, She failed the MOT with these areas and after poking around the rear parts of the sill's lots of corrosion and filler fell out, the corrosion has also got to the inner sills.
One of the main problems that I have come across is, you can't get repair panels for the rear section of the sill as it's part of the rear quarter panel, and the rest of the sill to the front is only available from Toyota, I've tried finding these sections with the companies that do the pattern repair panels but haven't had any joy.
Just two questions that I would like to ask are:
Do you paint the sill's before you weld them on and if so what with? Don't want the sill's to ignite!
I'll be cutting out the rot with a straight line along the top of the sill and drilling out the spot welds along the bottom lip, when I weld the sill in is it okay to put a full weld along the top, and with the MIG spot weld where the original spot welds would be along the bottom lip, it's just so the MOT chap is happy, or does it have to be seam welded all round?
Sorry if this doesn't make any sense.
Cheers
Trev
Cheers
Trev
