I did a quick google for inverter and it came back with ones costing hundreds, have you any links to what I need to get. Or better yet a "how I changed my drill to single phase" thread![]()
On early versions of the drill three choices of spindle end were available: a ordinary Jacobs No. 6 taper (to carry no. 34 Jacob chuck) or a long external taper having either a No. 1 or No. 2 Morse insert. While the latter two were adequate for light work, because the bottom speed was too high for use with larger drills it was decided (in the early 1990s, and rather late in the day) to modify the assembly by making that section of the head holding the clamp-on chuck guard an integral part of the casting. This increase in diameter and length allowed a larger, 25 mm ID bottom bearing to be fitted together with a bored-out quill assembly to take a spindle with either internal No. 1 or No. 2 Morse taper - or an external chuck-mounting Jacobs fitting. The later quill and spindle assembly can be used as a direct replacement in the earlier machines and substantially improve their drilling performance.
................. That's fine, I can see 1MT chucks on ebay that go up to 16mm. .................
a set of these u meanYou could use Blacksmith's drills if you need bigger than 16mm.
ive ended up buying large no 2 mt drills at autojumbles for about 3 to 4 quid each to fit in the tailstock on lathe the drill just gets up to half inch drills pluss they need to be run verry slow or chatter like hellFingers crossed indeed I haven't killed it. Hopefully not as its powering on in standby mode but when I switch the motor on it stops and gives a blinking warning light...
Does it matter which order the wires are for U, V and W?
