danny dorito
- South Satffordshire
im totally confused when it comes to paint that isn't cellulose. do all of the afore mentioned paint types require the same 2k thinners?
many thanks.
many thanks.
ok,
so if I used a VW reflex silver basecoat, I would need to mix with basecoat thinner, would this require hardener? and for clear coating could use 2k or 1k clear? is this correct?
many many thanks
can cellulose clear be used on top of basecoat? is basecoat as toxic as a 2k or can I get away with using a mask that I would use for cellulose?
sorry for all the questions, I don't want to screw it up and ruin my lungs at the same time.
many many many thanks
I guess the isocyanate is in the hardner then as the 2k thinners is the same as base coat thinners?
YAY, ive learnt something about paint at long last
Thank you for all of your help Mr Langy Sir.
What diy safe clear coat would you recommend for basecoat? ive heard not so good reports about the longevity of 1k clearcoat.
I only use 2k products so can't really suggest anything, I havn't used 1k for about 25 years !!!
