not seen it done but it will be expensive to run and a total waste of heat through a heat exchanger most heat will go up the chimneyJust in the thought stage at the moment but I am wondering about a log burner type stove fired with a propane ring to get rid of the condensation and keep the heat. Has this been done before?
Mike
The idea started while looking at my scrap pile, a fire extingusher, 13kg propane and two small butane cylinders plus a patio heater. I'm thinking stack the cylinders Saturn rocket style with a flue on top exiting the wall and the patio heater in the cutout bottom of the 13kg cylinder.(Awaits severe berating from the No!No!No! safety council!)
Show me your etchings please Jim!![]()
nowt to do with the health and safety police or the junta . my motto is if no one has made one before ask yourself why
lol get a long length of tube stick a propane burner in side of it and blow cold air over the outside of it , then measure how far along the heat travells and its temperature before it goes cold that will give u the answerit hasn't been invented yet![]()
What you're describing there my friend is a superser.![]()
i did similar, made a giant bunsen burner, but problem is the heat only came out of the top, the bunsen burner didnt get hot at all, its like the flame only burns when it gets outside the tube, think it needs extra oxygen or less momentum, or something
how about 3 oil drums stacked on there side connected together and fit baffel plates so the fumes have to snake around brfore going up the chimeny
