So I took out the gas fire in the living room and replaced it with an open fire, which is awesome! Lots of fun getting ash everywhere and heating little bits of metal up bright red
Despite how awesome the open fire is it has left me with a problem, the old gas fire surround was enormous and as a result of removing it the lower half of the chimney breast now needs to be re-plastered. I have tried a few plasterers I know but nobody wants to do it, probably because it's such a small job.. so I thought I might have a bash! its going to be papered anyway so the finish don't have to be amazing..
Any advice before I get on with it? when I was younger I worked on a job gutting houses and I remember the plaster washing the wall down with PVA water mix, to stop the brick being so porous? then putting a gloopy cement mix down with loads of lines scored in it.. I assume to give the final coat something to grip to? sort of like keying for paint? and then the plaster.
I realize it's not an easy thing to learn but I might as well give it a bash..
tips tips tips? other than "get a plasterer to do it"
best stuff to use is called hardwall backing plaster then finish off with wall finish . or board finish both simlar stuff but board finish takes slightly longer to go off . or u could use multi finish
