AndyStobbs
- North West England
Guy asks about a welder and gets lessons on bolt removal. You'll get enough heat in with 100 amps. I use this method on m12 wheel studs all the time with a 135A welder running at less than full power. Its not too late to shock the bolts. You could shock them prior to welding and again after the weld, while they're still hot. Be mindful where you put the earth clamp. Avoid any sealing faces.
. Within about 2mins he'd built up a stalk of weld long enough to grab with a mole grips a light twist and out it came
. To say I was impressed was an understatement I would never even considered attempting it especially using a big old oil cooled welder and full length 3.25mm rods
