Looking for a suitable Mig welder to weld nuts onto some broken cylinder head bolts on my car (bolt heads have rounded).
One solution I've been told is to weld a nut onto the rounded head.
I've never done welding before but reckon with some practice first I could do this.
The bolt studs are approx 12mm in diameter.
How many amps would a suitable mig welder need to be to put sufficient heat in do this. Bear in mind these studs are tight/maybe seized; only rounded because of this I guess and broke a good socket in my attempts to remove.
Thanks in advance
Thanks in advance
thats exactly what I meant, sometimes you just need that initial shock with some force in place
