secretsmoker
Beginning to wish I had not hired a welder now! I could not afford to buy a decent one so I thought rental would be better than buying a crappy one.
I collected this GYS SmartMIG 162 only this morning from UK toolhire Ilkeston and nothing but problems all day!
The most pressing issue is with the gas supply hoses. When I got it home and set everything up it was clear that gas was leaking from where the hose is clamped to the brass connector which attaches to the gas bottle. Obviously the machine isn't mine so no wanting to mess around with it and be blamed I called the hire company. Nobody was available to come to me so I had to take the thing back to them.
Went back to the hire place, they reclamped the hose but now it is leaking from the OTHER END of the hose where it connects to the machine itself. Not impressed. They obviously didn't test it and by the time I realised they had shut for the day. Needless to say I will probably be charged for the ferromaxx that has leaked out so far.
Probably going to have to go back to the hire place in the morning and very tempted to just ask for a refund for the inconvenience caused so far as I haven't actually managed to achieve anything in the first day of hire.
Other problems with very uneven wire feed and burnback. I am using 0.6 and when asked if I needed to change the sleeve the guy said the machine is set up with 0.6-0.8 sleeve?
I would love to try a different tip that I am sure is the correct size as I suspect the tip is also for 0.8 but I don't really want to spend any more money unless I am fairly sure of better results.
If I were to change the sleeve and tip to match the 0.6 wire, would that improve the burnback issues?
I have already gotten through 3 13amp fuses and tripped the circuit breaker numerous times. These problems seem to happen when the wire burns back to the tip and sticks, overloading the feeder which then fuses or trips out.
Incredibly annoyed so far as I have this thing for a week and I wanted to make some progress this evening. Instead work is on hold as I am worried about the gas leaking out.
Key point here appears to be that welder hire may not be for the beginner. Never really dealt with this hire company before so I am not sure how forthcoming they will be if I ask for an extra day!
So Frustrating!
So Frustrating!
Once empty and you go for a refill, don't ask for a replacement just tell them you want to do a return and transfer to the Volkszone offer. You will be credited back the remainder of the yearly rental on the existing bottle you are returning.
